Normal Topic scrollbar? (Read 1236 times)
nick
scrollbar?
Nov 6th, 2008 at 8:01pm
I am newbi here,
I am using diagram.MeasureUnit = Display
and drawing nodes in the code, in design mode there is no vertical scroll bar, but when i run it shows one even if my digram fits to the screen
one more problem is,
I am using tabs on one tab i am using Loadgraphics() which create the linked nodes but when i click on onother tab and switch back to the LoadGraphics() tab it draws copy of some of the nodes
even when I click on node and try to drag it, the douplicate single node is created without links, why this is happning?
thanks in advance
« Last Edit: Nov 6th, 2008 at 9:44pm by nick »
Re: scrollbar?
Reply #1 - Nov 7th, 2008 at 8:34am
You might set a smaller Diagram.Bounds value, or otherwise set DiagramView.ShowScrollbars = false.
Perhaps you are adding new nodes from the tabs' click/activated event handler?
