Normal Topic Custom cut, copy and paste (Read 2600 times)
tusharpateluk
Nov 10th, 2008 at 10:13am
Hi Stoyo,
I have created cutom diagramLink and Shape node. I have added custom properties to Shape node. I want to do customer cut, copy and paste based on type of the shape node.
If I used defualt functionality for WPFDiagram then, it will cut or copy what ever is selected.
What's the best way of doing these custom operations. Looking forward to your reply.
Re: Custom cut, copy and paste
Reply #1 - Nov 10th, 2008 at 11:49am
Do you need to copy to the clipboard other kinds of data, instead of the selected items? You can do that using the methods of the System.Windows.Clipboard class.
tusharpateluk
Reply #2 - Nov 10th, 2008 at 12:14pm
I need to copy data and also create outgoing links based on the type of the Shape node. So, their can be 1,2, or 3 links going out of the shape node based on the Shape node.
So, while pasting a shapenode, i need to lookup the type and then create additional links
Reply #3 - Nov 10th, 2008 at 1:25pm
You could create additional links from the handler of the NodePasted event.
tusharpateluk
Reply #4 - Nov 10th, 2008 at 2:13pm
