Normal Topic Box with a hyperlink (Read 1143 times)
wangqaa
Nov 12th, 2008 at 7:53am
Dear stoyo,
I search for key word "hyperlink" in discussion.
but I still not uderstand how to make a box with
a hyperlink in flowchart.
I just code
box.HyperLink="xxx";
it does not work...
can you kindly make a simple sample for me ?
thanks a lot
Re: Box with a hyperlink
Reply #1 - Nov 12th, 2008 at 11:39am
The Hyperlink is used mostly in the ASP.NET version of the control, or by the HtmlBuilder class in the WinForms version. If you need to open some URL when a box is clicked, you could do that from the NodeClicked event handler by calling Process.Start("iexplore.exe", box.Hyperlink).
