Normal Topic TableNode ? (Read 2183 times)
nick00
TableNode ?
Nov 14th, 2008 at 8:07pm
I have two quetions
1. I have table nodes with 2 columns, 3 rows and
I dont want the column separator.
as i want to show image in the first column and string in the other column of the same row, i have icon with 300X300 but it seems it is not showing up properly in the cell, can you suggest me for this.
2. Is there any way to cancel the draw link event , as I dont want to allow user to draw the link, the link get created from the database
Re: TableNode ?
Reply #1 - Nov 16th, 2008 at 9:12am
1. Set CellBorders = None and custom-draw the row separators using the DrawCell event handler.
2. If users should draw neither links nor tables, set DiagramView.Behavior = Modify.
nick00
Re: TableNode ?
Reply #2 - Nov 21st, 2008 at 7:40pm
Would you please little more specific,
as I am not getting property-CellBoarders
also for should i use
table.CellCustomDraw = CustomDraw.Additional;
Re: TableNode ?
Reply #3 - Nov 22nd, 2008 at 12:12pm
I meant set table.CellFrameStyle = None. CellCustomDraw = Additional should be ok, and then call e.Graphics.DrawLine() from the DrawCell event handler.
