Normal Topic We need a Panning Scroll. (Read 1659 times)
bemorem
MacPro Xeon Quad
Nov 25th, 2008 at 4:24am
Hi. Longtime No see ...
For Example, Click the flowchart document and
MouseDrag then, Moving the document...
But, Like below Behavior Type in FCX is may be not present in FC.Net...
FCX.Behavior:=bhPanAndModify;
How can I implement this function ?
Thanks in advance.
Flowchart .NET 4.3
Windows XP sp3
.Net Framework 3.5
VisualStudio2008 c#
HW: MacPro Xeon Quad/ 4GB RAM&&OS: WinXP sp3 / .NET 3.5&&Dev: VS 2008 C# sp1&&flowchart .Net ver 4.3.x&&
Re: We need a Panning Scroll.
Reply #1 - Nov 25th, 2008 at 7:15am
There is no PanAndModify behavior available in the .NET version. You can either use ALT to pan with the left button, or otherwise assign MouseButtonActions.Pan to RightButtonActions or MiddleButtonActions and use the respective mouse button without holding ALT.
bemorem
MacPro Xeon Quad
Reply #2 - Nov 26th, 2008 at 12:26am
Thanks!
It Helpful~
