Normal Topic Unable to access Layout functionality (Read 1736 times)
Sheldon
Nov 20th, 2008 at 2:04am
I am brand new to NetDiagram and have been working my way through some of the tutorials. I am interested in the TreeLayout object, but I find that "Dim TL As New TreeLayout" causes an error in my vb code: "Type 'TreeLayout' is not defined".
When I enter "Imports MindFusion.Diagramming.WebForms.", intellisense shows me four items to select from: ClientSideMode, DiagramView, Overview and ShapeListBox. If I ignore the intellisense and type Layout, VWD puts a squiggly line underneath and won't compile.
I have three dll's in my bin folder: Mindfusion.Common, MindFusion.Diagramming and MindFusion.Diagramming.WebForms. My vb code-behind file contains:
How can I get access to the Layout functionality?
Re: Unable to access Layout functionality
Reply #1 - Nov 20th, 2008 at 8:11am
Add an Imports MindFusion.Diagramming.Layout line.
Sheldon
Reply #2 - Nov 21st, 2008 at 1:06am
Thank you, Stoyan.  That did the trick.
