Hot Topic (More than 10 Replies) diagramView1.Behavior? (Read 10405 times)
nick00
Nov 24th, 2008 at 7:34pm
I know if I set
diagramView1.Behavior = DoNothing
diagram can not be edited.
But in my implimentation I want two things
1. Nodes and links are not editable
2. But i want to impliment zoomToRect functionality
which basically draws the trasparent Rectangle and zoom to rectagle and retangle is removed after zoom
how this is possible as donothing dont allow to do anything on the view but i just want to draw rect for zoomin
Re: diagramView1.Behavior?
Reply #1 - Nov 25th, 2008 at 7:09am
nick00
Reply #2 - Nov 25th, 2008 at 3:12pm
I have implimented this already, but my problem is i dont want to allow users to move link and nodes,
I know this zoomtorect will always create the new node trasferent for zoomto rect perpose.
just dont want to move the existing nodes and links
Reply #3 - Nov 25th, 2008 at 3:33pm
You could set Locked = true for each DiagramItem, or otherwise implement a custom behavior that never returns Action.Modify.
nick00
Reply #4 - Nov 25th, 2008 at 9:14pm
the things are working perfect except the one problem.
I used the code to draw link from the follwing link which you provide me to solve the link text strik to link line which is working perfect
http://mindfusion.eu/_samples/DrawLinkSample.txt
because of this code when i use zoomToRect for any LinkText it doen't show that text, on the zoom format i could see only the links
Reply #5 - Nov 26th, 2008 at 6:16am
With this code you get the labels drawn only when the Draw Link handler for the last link in the Z order is called. This might not happen when the link is not visible on the screen, e.g. when you zoom in a lot. Try to call Diagram.Invalidate() after zooming in, this should invalidate the whole diagram and raise the event.
nick00
Reply #6 - Nov 26th, 2008 at 2:28pm
??? its not happening
I used the code:
  private void diagram1_NodeCreated(object sender, NodeEventArgs e)
		ShapeNode node = e.Node as ShapeNode;
		if (!zoomToRectTool && node != null)
		    diagram1.Invalidate();
		    diagramView1.ZoomToRect (node.Bounds);
		   //tried here diagram1.Invalidate();
		    diagram1.Nodes.Remove(node);
		    zoomToRectTool = true;
		    diagramView1.ShowScrollbars = true;
		else
Reply #7 - Nov 26th, 2008 at 3:26pm
So the Draw method of that link is never called when the link is not inside the view. We have optimized the rendering code too well Wink Instead of drawing all labels from the DrawLink handler for a single link, try to handle the DiagramView.Paint event and draw the labels there.
nick00
Reply #8 - Nov 26th, 2008 at 4:09pm
I use this piece of code the program runs but now i cant see the link lables at all.
even zoomtorezt dont show any lables,
i debug the code it seems string are drawn.
I guess i am missing something
 private void diagramView1_Paint(object sender, PaintEventArgs e)
		System.Drawing.Brush textBrush = new System.Drawing.SolidBrush(Color.Black);
		System.Drawing.Brush backBrush = diagram1.BackBrush.CreateGdiBrush(diagram1.Bounds);
		foreach (DiagramLink l in diagram1.Links)
		    int s = l.SegmentCount / 2;
		    PointF p1 = l.ControlPoints[s];
		    PointF p2 = l.ControlPoints[s + 1];
		    float iX;
		    if (p2.X < p1.X)
			  iX = p2.X + 10F;
		    else if (p2.X > p1.X)
			  iX = p2.X - 10F;
		    else
			  iX = (p1.X + p2.X) / 2;
		    PointF c = new PointF(iX, (p1.Y + p2.Y) / 2);//(p1.X + p2.X) / 2
		    SizeF textSize = diagram1.MeasureString(l.Text, l.Font, int.MaxValue, StringFormat.GenericDefault);
		    float w = textSize.Width;
		    float h = textSize.Height;
		    RectangleF textRect = new RectangleF(c.X - w / 2, c.Y - h / 2, w, h);
		    StringFormat stringFormat = new StringFormat();
		    stringFormat.Alignment = StringAlignment.Center;
		    stringFormat.LineAlignment = StringAlignment.Center;
		    e.Graphics.FillRectangle(backBrush, textRect);
		    e.Graphics.DrawString(l.Text, l.Font, textBrush, textRect, stringFormat);
		backBrush.Dispose();
		textBrush.Dispose();
Reply #9 - Nov 26th, 2008 at 6:55pm
Try it with the following lines added to the top of the Paint handler -
float scale = diagramView.ZoomFactor / 100F;
e.Graphics.PageUnit = diagram1.MeasureUnit;
e.Graphics.ScaleTransform(scale, scale);
e.Graphics.TranslateTransform(-diagramView.ScrollX, -diagramView.ScrollY);
nick00
Reply #10 - Dec 1st, 2008 at 2:49pm
now i am facing some problem
When i draw the rectagle for zoom,
over the link lable , the only link lable (not link) gets disappear
after zoom to rect is done, it shows the link lable properly (zoomed)
Reply #11 - Dec 2nd, 2008 at 7:11am
We've added a better event for doing this,:
https://mindfusion.eu/_temp/fcnet_drawfore.zip
It's called DrawForeground and is in the Diagram class. It should work also while drawing with the mouse. Handle it like this:
[code]
private void diagram_DrawForeground(object sender, DiagramEventArgs e)
     System.Drawing.Brush textBrush = new System.Drawing.SolidBrush(Color.Red);
     System.Drawing.Brush backBrush = diagram.BackBrush.CreateGdiBrush(diagram.Bounds);
     foreach (DiagramLink l in diagram.Links)
           PointF c = new PointF((p1.X + p2.X) / 2, (p1.Y + p2.Y) / 2);
           SizeF textSize = diagram.MeasureString(l.Text, l.Font, int.MaxValue, StringFormat.GenericDefault);
           e.Graphics.DrawString(l.Text, l.Font, textBrush, textRect, StringFormat.GenericDefault);
[/code]
nick00
Reply #12 - Dec 2nd, 2008 at 10:23pm
is this for VS2005 version?
Do I need to override the dll of local VS2005?
thanks,
Reply #13 - Dec 3rd, 2008 at 6:30am
Unzip the dlls into a folder and add the folder to the top of your project's reference paths list. Additionally, disable the "Use specific version" property for the mindfusion.* references, if it's enabled.
Reply #14 - Dec 16th, 2008 at 6:42am
The only reasons I can think of FillRectangle would work and DrawString would not is that either l.Text is an empty string or textBrush is white / transparent. You could add a breakpoint on that line and check if all values passed as arguments to DrawString are ok.
