Normal Topic PrintPreview! (Read 1886 times)
nick00
PrintPreview!
Nov 25th, 2008 at 9:26pm
1. Is there any way to set midparent to the PrintPreview() form
2. Also if I use PrintPreview() then can i have any way to minimize the printpreview form as by defalut the minimize option is disable
3. for print preview i used
diagramView1.PrintOptions.DocumentName = "ABC";
it appearing on the preview as a title like
ABC , Page 1
I dont want that space after "ABC"
Re: PrintPreview!
Reply #1 - Nov 26th, 2008 at 6:12am
1. What does "midparent" mean?
3. Set PrintOptions.HeaderFormat.
nick00
Re: PrintPreview!
Reply #2 - Nov 26th, 2008 at 2:39pm
Cheesy thanks it works
u r gr8
MIDParent is assigned to general form then the form remains withine application,
e.g. if you minimize the form withing appication it is shown on appications task bar not minimizes whole application.
Dlg.MdiParent =this.parentWindow;
Re: PrintPreview!
Reply #3 - Nov 26th, 2008 at 3:17pm
You will have to create your own print preview form, add the standard .NET PrintPreviewControl to it, and implement the IPrintPreview interface defined by Flowchart.NET. IPrintPreview defines only one property, Document, whose implementation should just delegate to the PrintPreviewControl.Document. Once the form is ready, you can use the public void PrintPreviewEx(Form previewForm) method of DiagramView to display the preview.
