Normal Topic Detect connected anchorpoint (Read 2149 times)
lindborg
Dec 1st, 2008 at 9:44am
How can I detect which anchorpoint that is connected to a link? I would like to recolor the connected anchorpiont when a links is connected.
Re: Detect connected anchorpoint
Reply #1 - Dec 1st, 2008 at 10:11am
In the LinkCreated and LinkModified handlers check the OriginAnchor or DestinationAnchor properties, depending on which AdjustmentHandle has been used. The *Anchor properties return the indices of the anchor points to which the link is connected.
marie
Reply #2 - Dec 10th, 2008 at 5:11pm
I have a question related to this.
How do I set the color back when all links have been deleted from an anchor point? I can use LinkDeleted, but I don't know if there are other links that are still attached to OriginAnchor and/or DestinationAnchor...
Marie
Reply #3 - Dec 11th, 2008 at 12:24pm
You'll have to iterate over all links attached to the node and check if any of them still has this point as Origin/DestinationAnchor.
marie
Reply #4 - Dec 11th, 2008 at 2:05pm
Hi Stoyan,
I'll do that then!
Thanks Smiley
Marie
