Normal Topic PDF Export - Bitmaps with transparency (Read 2178 times)
jdd48
Dec 10th, 2008 at 5:53am
I am using transparent nodes with the background image of the node set to a Bitmap object. I want to make all white in the Bitmap transparent, so I call MakeTransparent(Color.White) on the Bitmap before setting it to the background image of the node. This works fine on the diagram itself - white sections are transparent as expected. However when I export to PDF, I am getting more than just the white transparent sections excluded in the PDF. Some black sections surrounding the white are also getting excluded. Any help would be appreciated! Thanks.
Re: PDF Export - Bitmaps with transparency
Reply #1 - Dec 10th, 2008 at 6:02am
What version of the control are you using? I believe our developers fixed some PDF transparency problems in the 5.1.1 release.
jdd48
Reply #2 - Dec 10th, 2008 at 1:07pm
Ahh - you're right. I'm using 5.1.0.3387. Where may I download 5.1.1? I did pay for the 5.1.0 version, but I don't see where upgrades of the full version are available. Thanks.
jdd48
Reply #3 - Dec 10th, 2008 at 1:32pm
A quick update as well - I downloaded the trial version in the meantime to test transparency, and it did export as it should have. Thanks.
Reply #4 - Dec 10th, 2008 at 1:43pm
We send upgrades by e-mail, and you should have received yours on the 15th of October. Now you can find a download link on the private messages page.
jdd48
Reply #5 - Dec 10th, 2008 at 1:55pm
Fantastic - thanks alot!
