Normal Topic WpfDiagram versus FlowChartNet (Read 1527 times)
WrayKS1
Dec 8th, 2008 at 3:41pm
From what I understand these two components do roughly (if not exactly) the same things.
Can anyone point out any differences or comparisions between them that would help make a decision on which one. I don't want to get deep into design and find out the differences after purchase. We are developing on .NET 3.5 so framework is not a limitation.
Re: WpfDiagram versus FlowChartNet
Reply #1 - Dec 8th, 2008 at 6:01pm
They offer mostly the same features. The biggest difference is that the Windows Forms Flowchart.NET control supports multiple views on the same diagram, while the WPF version does not. Flowchart.NET also comes with several import/export components that are not yet available in WpfDiagram. What the WPF version is better in is using other controls as nodes, if you need such thing.
