Normal Topic ShapeNode.ResizeToFitImage (Read 1806 times)
TheMonkey
Dec 12th, 2008 at 3:39pm
Under "Items Placement - Position, Size and Z-order" -> "Location and Size of Nodes" in the documentation, it says that "ShapeNode.ResizeToFitImage [...] methods set nodes' sizes to fit that of their pictures".
I cannot find this method.
How does one resize to fit contents of a shapenode anyway? I have set the contents to be a UserControl, but the bounds do not change to surround this control.
Also, I can select the node by clicking my control, but trying to drag it causes SL to crash.
Re: ShapeNode.ResizeToFitImage
Reply #1 - Dec 12th, 2008 at 4:01pm
Have you added the UserControl to a ShapeNode? You should use ControlNodes to host custom controls.
