Hot Topic (More than 10 Replies) Attached shape node in container (Read 4922 times)
marie
Dec 15th, 2008 at 4:11pm
I have table nodes in a container. When I fold the container, the shape nodes that are attached to the table nodes remain painted at their old position instead of being hidden as they should. How can I fix that?
Note: When I move the folded container, the shape nodes are moved and if I unfold it, it's fine.
Also, when I fold the container, the width is changed (it gets so small that the caption doesn't fit anymore). The width seems to be set to diagram.ContainerMinimumSize.Width. How can I fix that 2nd problem?
Marie
« Last Edit: Jan 6th, 2009 at 5:51pm by marie »
marie
Re: Attached shape node in container
Reply #1 - Dec 15th, 2008 at 9:02pm
I have a 3rd question. How do I move a node programatically within a container? When the node is added to the container, it gets moved to a default position and after that I don't know how to change its position programatically. I tried using node.Bounds.X & Y, but a change in those doesn't visually move the nodes.
Marie
Reply #2 - Dec 16th, 2008 at 6:36am
After attaching the shape nodes, set table.SubordinateGroup.FollowMasterContainment = true.
To move a node inside a container set the node's Bounds and call container.UpdateBounds().
marie
Reply #3 - Dec 16th, 2008 at 12:45pm
Hi Stoyan,
Thanks Smiley
However, you forgot one question again:
When I fold the container, the width is changed (it gets so small that the caption doesn't fit anymore). The width seems to be set to diagram.ContainerMinimumSize.Width. How can I fix that problem?
Marie
Reply #4 - Dec 16th, 2008 at 2:03pm
Hi Marie,
We'll have to add some property to let you control that. For the time being you could handle the ContainerFolded event, call Diagram.MeasureString(caption), and if container.Bounds.Width is smaller than what MeasureString() returns, assign to it a larger RectangleF.
marie
Reply #5 - Dec 16th, 2008 at 2:04pm
Hi Stoyan,
Is it possible to catch when the container is folded and change its width to fit the original width? I can see the original width in the private members of the container, I just don't know if/how to access it...
For now, it's annoying, because if I want to toggle between folded/unfolded, I need to move the mouse in between...
Marie
Reply #6 - Dec 16th, 2008 at 2:31pm
You could handle ContainerFolded, see above. If you can see the original width through the debugger, you could use reflection to get the value of that field. We'll add some property to let you access it in the next release.
marie
Reply #7 - Jan 6th, 2009 at 2:31pm
Hi!
I did that (the field name is x3dd386b2ed9f5b71). Do you know if a next release is planned soon?
Happy New Year!
Marie
Reply #8 - Jan 6th, 2009 at 3:58pm
Happy New Year!
We'll release it in a couple of weeks. I can send you a pre-release build if you need it urgently.
marie
Reply #9 - Jan 6th, 2009 at 5:51pm
Thanks Cheesy !
I can wait. I did the fix meanwhile.
Marie
Reply #10 - Jan 7th, 2009 at 10:45am
I've sent you a download link on the private message page anyway. Now there is ContainerNode.UnfoldedSize property, please check if it works well for you.
