Normal Topic SaveLoadSample (Read 1870 times)
elmarquez
SaveLoadSample
Dec 15th, 2008 at 8:03pm
I get an exception in the SaveLoadSample demo. It occurs in Page.xaml.cs in the OnLoad method, line 51.
var xml = input.GetProperty("value").ToString();
Here's the exception detail.
System.NullReferenceException was unhandled by user code
Message="Object reference not set to an instance of an object."
StackTrace:
at SaveLoadSample.Page.OnLoad(Object sender, RoutedEventArgs args)
at System.Windows.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName)
InnerException:
Otherwise, the demos look great.  I'm happy to see the Silverlight library developing.  Thank-you.
Re: SaveLoadSample
Reply #1 - Dec 16th, 2008 at 10:19am
Set SaveLoadSample.Web as the startup project before running the sample with F5, or use the "view in browser" command from the SaveLoadSampleTestPage.aspx context menu.
