Normal Topic Nodes are dragged out of Diagram? (Read 3705 times)
chris
Dec 17th, 2008 at 9:13pm
Hi Stoyan,
When I drag and drop a node to the far top end of the window(out of the Diagram control), the node is disappeared. Because it is dragged out of the Diagram control. I can't move the scroll bar to the
top to bring it back.(It is already at the topmost end.)
But there is no such problem in the sample projects.
How can I do to prevent the nodes to be dragged out of a Diagram?
Thanks a lot.
Re: Nodes are dragged out of Diagram?
Reply #1 - Dec 17th, 2008 at 9:18pm
Hi Chris,
You could enable either the RestrictItemsToBounds or AutoResize property of the Diagram.
chris
Reply #2 - Dec 17th, 2008 at 11:04pm
Hi, Stoyan,
It doesn't work. I tried all kinds of values but the can still be dragged out.
I checked a sample project.
The AutoSize property uses the default value RightAndDown and the RestrictItemsToBounds uses defautl value Intersection in the project.
They are not set by code and the nodes can not be dragged out.
Thanks.
chris
Reply #3 - Dec 17th, 2008 at 11:25pm
In the same time, when a node is dragged out of the Diagram, the Overview control in another window changes postion and can't be changed back.
Thanks.
Reply #4 - Dec 18th, 2008 at 6:25am
I've tried this in a new project, and the nodes cannot be dropped out of the diagram by default. Could you copy here your XAML for the diagram, and any initialization code that runs from the window.Loaded event handler? By drag and drop you mean selecting and moving a node in the diagram, and not OLE drag and drop between different controls on the form, right?
chris
Reply #5 - Dec 18th, 2008 at 4:05pm
I got it!
I set the AutoRize to AllDirections. It doesn't work.
The default value RightAndDown works.
Thanks Stoyan.
Reply #6 - Dec 18th, 2008 at 4:16pm
Hi Chris,
Regarding the overview disappearing when auto-resizing, you can find a patch for this in the latest posts in the bug-report section. We'll release an official fix with version 2.0.1 next week.
