Normal Topic Layout problem? (Read 2302 times)
chris
Layout problem?
Dec 19th, 2008 at 11:37pm
Hi Stoyan,
I use the following code to append a label under a ShapeNode.
    ShapeNode node = diagram.Factory.CreateShapeNode(40, 40, 80, 40);
     node.EnabledHandles = AdjustmentHandles.Move;
    node.Shape = Shape.FromId("...");
     ShapeNode labelNode = Canvas.Factory.CreateShapeNode(0, 80, 80, 20);
        labelNode.AttachTo(node, AttachToNode.BottomCenter);
     labelNode.Locked = true;
     labelNode.Text = "Label";
     labelNode.Transparent = true;
     node.SubordinateGroup.AutoDeleteItems = true;
        node.SubordinateGroup.FollowMasterContainment = true;
When I define a Layout and call the Arrange method, the labe node is regarded as a normal ShapeNode and is separated from the master node.
        LayeredLayout layout = new LayeredLayout();
        // Perform the actual arrangement
        layout.Arrange(diagram);
Is it a bug for Layout?
Thanks a lot!
Re: Layout problem?
Reply #1 - Dec 19th, 2008 at 11:45pm
Hi Chris,
Set labelNode.IgnoreLayout = true, or layout.KeepGroupLayout = true.
chris
Re: Layout problem?
Reply #2 - Dec 22nd, 2008 at 8:53pm
Thanks Stoyan.
Merry Christmas and happy new year!
Re: Layout problem?
Reply #3 - Dec 23rd, 2008 at 6:03am
Merry Christmas to you too 8)
