Normal Topic Set a ShapeNode to Focus? (Read 2131 times)
chris
Dec 23rd, 2008 at 5:54pm
Hi Stoyan,
I need to synchronize another grid control with my Diagram control. That means when a ShapeNode is clicked, I need to select a correspondent row in another grid control.
The problem is the focus of the keyboard is changed to the grid control. I can't use Del key to delete the clicked ShapeNode.
I tried to call ShapeNode.Focus() function
and System.Window.Input.Keyboard.SetFocus(node) to set the focus item back to the ShapeNode. It doesn't work.
Is there a way to implement this feature?
Maybe this is my last question for 2008. Thank you very much for your great help. Best wishes for the new year!
chris
Re: Set a ShapeNode to Focus?
Reply #1 - Dec 23rd, 2008 at 6:08pm
Hi Stoyan,
I got it! The reason why I can't set the ShapeNode to focus is that the default value of Focusable property of the ShapeNode is false.
After I set it to true, it works. By the way, is there any side effects if I set the Focusable property to true?
Thanks.
Reply #2 - Dec 23rd, 2008 at 7:24pm
Hi Chris,
The control doesn't handle keyboard events at all, but uses command bindings, for example to ApplicationCommands.Delete. I believe routed commands are handled first by the parent controls of the focused item, so setting the node to focus should not prevent the command from getting to the diagram.
