Normal Topic WpfDiagram V2.1 beta (Read 4982 times)
Jan 6th, 2009 at 7:19am
https://mindfusion.eu/_beta/wpfdiag21.zip
This version contains two new layout classes. OrthogonalLayout, which arranges the items like this:
and CircularLayout:
Note that the OrthogonalLayout class available in previous versions, which actually arranges only the links while preserving node positions, is now called OrthogonalRouter.
We have also ported the LaneGrid feature from Flowchart.NET, and improved PdfExporter considerably.
Many thanks to anyone who tries this beta version.
Re: WpfDiagram V2.1 beta
Reply #1 - Jan 14th, 2009 at 7:50am
We have uploaded new assemblies that fix a couple of bugs:
The archive also contains an updated help file for version 2.1.
Paul Eden
Reply #2 - Jan 20th, 2009 at 12:39pm
Not sure if it's just my machine, but the help file reports that the  "address is not valid" on every page.
Paul
Reply #3 - Jan 20th, 2009 at 1:34pm
This happens if you access it from a network location, is that so?
Paul Eden
Reply #4 - Jan 20th, 2009 at 2:23pm
No, at first I thought it was because I was running it out of the zip file (which proabably didn't help anyway) but even after extracting it to my local disk the same issue occurrs.
Reply #5 - Jan 20th, 2009 at 2:27pm
What IE version are you using?
Paul Eden
Reply #6 - Jan 20th, 2009 at 2:28pm
Version 7, on Windows Vista.
Reply #7 - Jan 20th, 2009 at 2:54pm
Did the help file from the old version work correctly?
Paul Eden
Reply #8 - Jan 21st, 2009 at 10:07am
Yes, a help file dated 2008 works no problems.
