Normal Topic Add an unique identifier (Read 2323 times)
mberger
Jan 6th, 2009 at 9:56pm
for my application i have to create some IconNodes.
Therefore i have copy and paste the IconNode class from the sample files.
Is it possible to add this IconNodes an unique identifier like a index or a name (In the same way i would like to add an index or name to a link)?
best regards
Marco
Re: Add an unique identifier
Reply #1 - Jan 7th, 2009 at 8:31am
You could add the following to the IconNode class:
public Guid UniqueID
     get { return uniqueID; }
private Guid uniqueID = new Guid();
and these two lines to the serialization methods:
// in Saveto
writer.Write(uniqueID.ToString());
// in LoadFrom
uniqueID = new Guid(reader.ReadString());
mberger
Reply #2 - Jan 7th, 2009 at 3:34pm
...thanks a lot for your help! Cheesy
But this wasn't the property that im searching for!
for explanation:
I would like to write a little application to calculate the mass flow in a pipe network. this network should be created with some different IconNodes.
After the creation of the IconNode during the runtime, i need a unique name or index for each node to accessing them or to set some values in arrays for a selected node.
for example:
name node 1: Node_1
name node 2: Node_2
name node 3: Node_3
Array's
Arr_Node_1_Value_1 = "xxx"
Arr_Node_2_Value_1 = "yyy"
and so on...
(sorry for my poor english... Embarrassed )
best regards
Marco
Reply #3 - Jan 7th, 2009 at 3:57pm
You could add some string ID property similarly to how IconNode.Label is defined, and use the Dictionary class from System.Collections.Generic to map IDs to Nodes.
« Last Edit: Jan 8th, 2009 at 6:42am by Stoyo »
Aziz ur Rahman
Reply #4 - Jun 9th, 2009 at 12:58pm
If Diagram is saved to XML, then each node and each link will be given a unique Id
e.g.
<Node Class="Terminator" Id="1" Version="1">
OR
<Link Class="std:DiagramLink" Id="5" Version="1">
But this "Id" attribute is not exposed in the object model of node or link.
Can u please expose it so that I donot have to go through all the custom labor work mentioned by you.
Syed Aziz ur Rahman
Reply #5 - Jun 9th, 2009 at 6:05pm
That's the value of the ZIndex property of items. You could use it as an id when saving the diagram; ZIndex will have values ranging from 0 to the number of items - 1. However the ZIndex value changes when deleting items or when you call Z order related methods, so you can't use it as a general purppose id that will always refer to the same item. You might assign your IDs each time when a new item is created by using the .NET Guid class, e.g. in NodeCreated handlers:
e.Node.Tag = (new Guid()).ToString();
