Normal Topic Rearrange Path (Read 1598 times)
khstar
Rearrange Path
Jun 9th, 2009 at 1:23am
How can I rearrange a path?
Is there any way to rearrange a path?
I just want to change a start point in cycle path.
3 > 4 > 5 > 1 > 2 > (3)
the above has to be changed like below
1 > 2 > 3 > 4 > 5 > (1)
And I cannot put same node twice to a path.
in my app, I need to put same item twice.
But it doesn't work by 'add' method.
Would you show me the way?
Re: Rearrange Path
Reply #1 - Jun 9th, 2009 at 5:01am
Try this method:
void ShiftPath(DiagramNodeCollection path, int step)
	List<RectangleF> boundsList = new List<RectangleF>();
	foreach (DiagramNode node in path)
		boundsList.Add(node.Bounds);
	for (int i = 0; i < path.Count; ++i)
		path[i].Bounds = boundsList[(i + step) % path.Count];
		DiagramLinkCollection links = node.GetAllLinks();
		foreach (DiagramLink link in links)
			link.Route();
The same node cannot be displayed at two different positions. You will have to create an additional node representing the same business object of yours.
khstar
Re: Rearrange Path
Reply #2 - Jun 9th, 2009 at 6:31am
pathfinder returned pathcollection, not diagramnodecollection. ???
How can I modify your code?
Re: Rearrange Path
Reply #3 - Jun 9th, 2009 at 8:05am
Change the type of the "path" argument to Path, and then loop over path.Nodes:
foreach (DiagramNode node in path.Nodes)
