Normal Topic Netdiagram v2.1 (Read 2362 times)
rjulianc
Netdiagram v2.1
Jan 7th, 2009 at 4:31am
Hi I've just upgraded my application to use NetDiagram 2.1, as it says it supported Java 6 updates 10 and 11 JRE version.
but after the upgrade I get:
java.lang.NoSuchFieldException: getShadowColor in class: com.mindfusion.diagramming.ShapeNode
java.lang.NoSuchFieldException: getKeyCode in class: java.awt.event.KeyEvent
My application rely heavily on clientside javascript, and who knows how many other errors it produce after the upgrade, it was working perfectly with the older version.
What do I need to do fix this? does this mean I have to redo all the javascript codes to reflect to the new version?
Re: Netdiagram v2.1
Reply #1 - Jan 7th, 2009 at 8:22am
function onNodeClicked(sender, args)
	// this works
	var color = args.getNode().getShadowColor();
	alert(color);
	// this throws an exception
	var color2 = args.getNode().getShadowColor;
	alert(color2);
rjulianc
Re: Netdiagram v2.1
Reply #2 - Jan 8th, 2009 at 6:13am
This is working, thanks
