Normal Topic Replace position between 2 objects (Read 3591 times)
tzippy
Jan 11th, 2009 at 1:31pm
How can I replace the position between 2 nodes in a diagram?
10X
Re: Replace position between 2 objects
Reply #1 - Jan 11th, 2009 at 2:27pm
Rect r1 = node1.Bounds;
node1.Bounds = node2.Bounds;
node2.Bounds = r1;
tzippy
Reply #2 - Jan 12th, 2009 at 9:33am
Thank for reply.
I would want to reorder the items by layout, and keep the new positions.
Is there a property which get the order of the items in the layout?
Reply #3 - Jan 12th, 2009 at 10:39am
You need for a pair of nodes to be always placed the first on the left and the second on the right? You could try attaching the second node to the first one (method AttachTo), and then use the KeepGroupLayout property of the layout classes.
tzippy
Reply #4 - Jan 12th, 2009 at 12:24pm
I want to replace between 2 nodes,
but they not necessarily next to each other.
Reply #5 - Jan 12th, 2009 at 1:13pm
If you are using TreeLayout, just create the links to child nodes in the order you need them - TreeLayout uses the order of outgoing links to deterine the child placement order. Or after applying the layout, see if the nodes you need in specific order are placed in the opposite order, and if so, swap their positions as shown above.
tzippy
Reply #6 - Jan 12th, 2009 at 2:52pm
Your answer helped me.
