Normal Topic Diagram size (Read 1611 times)
vtortola
Diagram size
Jan 14th, 2009 at 1:42pm
Is it not possible fill the parent with the design surface (the area with the grid)?
Seems like the width can't be bigger than 800. There is not possibility of fill with the surface and limit the zoom to the surface measures?
Cheers.
Re: Diagram size
Reply #1 - Jan 14th, 2009 at 2:24pm
Set large enough Diagram.Bounds, and the diagram should fill the parent. It is the Bounds' size returned as result during the WPF measure pass.
