Normal Topic Draw pictures on nodes (Read 3549 times)
vtortola
Jan 12th, 2009 at 3:20pm
Back to work after long holidays...
I'd like add pictures to shapes, I've tried with the DrawNode event, drawing a picture in the node bounds... but the pictures appears in wrong positions with Additional2 mode, and with Additional mode only appear two :S.
I've seen in the demo showcase some diagrams with pictures, but that example is not in the examples folder... could you provide me the piece of code that put a picture on a node or tell me where I could find that example.
Thanks.
Re: Draw pictures on nodes
Reply #1 - Jan 12th, 2009 at 3:29pm
ShapeNode.Image = Utilities.LoadImage(...);
vtortola
Reply #2 - Jan 12th, 2009 at 3:43pm
Sorry I mean... above the shape, not inside Tongue
My fault.
Reply #3 - Jan 12th, 2009 at 3:49pm
Smiley If you've seen such images in the demo, perhaps they are loaded inside a Transparent helper node attached to the main node. The custom-draw events might require you to draw in local coordinates relative to the nodes' top-left point.
vtortola
Reply #4 - Jan 13th, 2009 at 1:18pm
Thanks.
Cheers.
Reply #5 - Jan 13th, 2009 at 1:23pm
Are you setting ShapeNode.Transparent? If so, what don't you like about it?
vtortola
Reply #6 - Jan 14th, 2009 at 4:16pm
That was the problem, I didn't realize there was that property exists. I guessed I'd modified the post quick enough... but you were quick answering Cheesy
Working fine, thanks.
Cheers.
