Normal Topic Java JRE 6_11 NetDiagram 2.0 IE 7 (Read 3967 times)
daniVerz
Jan 27th, 2009 at 2:06pm
I'm using NetDiagram 2.0. After a normal JRE update the application started to show erros such as:
Unspecified error invoking method or accessing property "onBoxSelected"
netscape.javascript.JSException: Unspecified error invoking method or accessing property "onBoxSelected"
at sun.plugin2.main.client.MessagePassingJSObject.newJSException(Unknown Source)
at sun.plugin2.main.client.MessagePassingJSObject.waitForReply(Unknown Source)
at sun.plugin2.main.client.MessagePassingJSObject.call(Unknown Source)
at com.mindfusion.jdiagram.FlowChartApplet.b(Unknown Source)
at com.mindfusion.jdiagram.FlowChartApplet.itemSelected(Unknown Source)
at com.mindfusion.jdiagram.FlowChart.e(Unknown Source)
at com.mindfusion.jdiagram.Item.putSelected(Unknown Source)
at com.mindfusion.jdiagram.Selection.a(Unknown Source)
at com.mindfusion.jdiagram.Selection.addItem(Unknown Source)
at com.mindfusion.jdiagram.FlowChart.loadFromXml(Unknown Source)
at com.mindfusion.jdiagram.FlowChart.a(Unknown Source)
at com.mindfusion.jdiagram.FlowChartApplet.loadFromString(Unknown Source)
at com.mindfusion.jdiagram.FlowChartApplet.init(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Any ideas?
Thanks.
Re: Java JRE 6_11 NetDiagram 2.0 IE 7
Reply #1 - Jan 27th, 2009 at 3:51pm
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=122717317...
Try this with version 2.1. You should have received the upgrade a few weeks ago.
daniVerz
Reply #2 - Jan 27th, 2009 at 4:26pm
Stoyan,
I didn't receive the email. I saw the solution in the topic you pointed out. The question is: should I move to 2.1 or is there a patch for 2.0? Am I licensed for 2.1?
Regards.
Reply #3 - Jan 27th, 2009 at 4:32pm
Yes, you are. Now you can find the link on the private messages page.
