Normal Topic Flashes of components appear when running layout (Read 2532 times)
ymoran00
Jul 30th, 2007 at 7:56am
This is an odd thing.
It seems that about 80% of the times I'm running the layout() method fro a FlowChart, for about 0.5 a second I see a static screen capture in the place of the FlowChart.
I'll try to explain: in a flash I see the Overview inside the FlowChart, or my Refresh button that exists outside of the chart suddenly appears inside it. It's as though as screen capture is pasted there or something like that.
Re: Flashes of components appear when running layo
Reply #1 - Jul 30th, 2007 at 10:35am
Do you run the layout after closing another window or dialog? JDiagram uses the Java double-buffering feature, and the buffer content might not be refreshed yet if running the layout immediately after closing a window. Try calling the FlowChart.repaint() method before Layout.arrange(). That should repaint the flowchart and also update the back-buffer.
ymoran00
Reply #2 - Jul 30th, 2007 at 11:34am
This solved the problem!
I've added repaint before the layout, and all went well.
Yoav
