Normal Topic Bug in OnSerializeTag and OnDeserializeTag (Read 1759 times)
castefani
Mar 26th, 2009 at 5:00pm
Derive a class of Diagram and outweighs the methods
override void OnSerializeTag
and
protected override void OnDeserializeTag
Calling SaveToString after LoadFromString then SaveToString, beast last call and subsequent calls are not the methods OnSerializeTag and OnDeserializeTag
EX:
In the method test (), the 2nd called SaveToString, the methods OnSerializeTag and OnDeserializeTag will not be called.
class MyDiagram : Diagram
string diagramId = "Test";
protected override void OnSerializeTag(SerializeTagEventArgs e)
base.OnSerializeTag(e);
XElement el;
var els = e.Context.XDocument.Root.Descendants("MyData").ToList();
if (els.Count > 0)
el = els[0];
else
el = new XElement("MyData");
e.Context.XDocument.Root.Add(el);
e.Context.WriteString(diagramId, "DiagramId", el);
ª
protected override void OnDeserializeTag(SerializeTagEventArgs e)
base.OnDeserializeTag(e);
if (els.Count > 0)
var el = els[0];
diagramId = e.Context.ReadString("DiagramId", el, Guid.NewGuid().ToString());
public void TEST()
           string save = this.SaveToString(SaveToStringFormat.Xml);
           this.LoadFromString(save);
Re: Bug in OnSerializeTag and OnDeserializeTag
Reply #1 - Apr 6th, 2009 at 12:21pm
I can't quite understand this, but you should also set e.Handled = true in SerializeTag and DeserializeTag handlers.
