Normal Topic Anneal Layout Randomness (Read 2985 times)
jmquinlan
Apr 8th, 2009 at 10:15am
In regards to this discussion I think I have found a bug.
http://mindfusion.eu/Forum/YaBB.pl?board=general;action=display;num=1239009408
The anneal layout is dependent on the initial positions of the nodes, if the initial positions and sizes are the same then the output of the AnnealLayout arrange method should be the same. That is what I understood from the above discussion.
What I have found is that even if my initial positions are the same and also my initial sizes, the anneal layout arrange method produces different results. Also I set the Randomise flag on the anneal layout to false.
I still get a random layout each time I reload my diagram.
jmquinlan
Re: Anneal Layout Randomness
Reply #1 - Apr 8th, 2009 at 10:16am
please note that the layout parameters are the same each time I reload my diagram.
Reply #2 - Apr 9th, 2009 at 8:41am
Yep, seems we broke this when we added the LayoutArea property. Nodes that are not in the LayoutArea are still randomized, and the default LayoutArea is an empty rectangle Smiley As a work-around you could set LayoutArea = diagram.Bounds before calling Arrange.
jmquinlan
Reply #3 - Apr 14th, 2009 at 9:04am
Thanks Ill give that a go
jmquinlan
Reply #4 - Apr 14th, 2009 at 9:35am
it seems that setting the layout area works Smiley cheers guys Smiley
FIXED
