https://mindfusion.eu/_beta/fcnet52.zipThis archive contains only the updated assemblies. You need an existing Flowchart.NET installation to be able to use them in design-time.
This version contains two new layout classes. OrthogonalLayout, which arranges the items like this:
and CircularLayout:
Note that the OrthogonalLayout class available in previous versions, which actually arranges only the links while preserving node positions, is now called OrthogonalRouter.
Version 5.2 also includes many customer requested features:
~ the LinkHitDistance property lets you specify how far from links a click should be considered a hit
~ link labels are now rendered in DiagramView3D
~ LaneGrid cells can display text
~ LaneGrid rows and columns can be inserted interactively
~ DrawForeground event
~ resizing nodes with the KeepRatio constraint always fixes the corner opposite to the handle being dragged
~ SnapToNodeBorder is now considered also when creating links
~ ContainerNode.UnfoldedSize
~ now AnchorPatterns can be associated with Shape definition
~ Shape objects can be defined without an outline. This and the feature above can be useful for defining electrical shapes
Even if you don't try any new features, it still helps us a lot to check if your existing applications run fine with the new version.
Many thanks to anyone who tries this beta version!
