Hot Topic (More than 10 Replies) Page size on printing (Read 7753 times)
vtortola
Jan 28th, 2009 at 1:26pm
Hi there,
Is there possibility of specify the page size ?
I saw in the Pdf export is possible, but in printing ?
Cheers.
Re: Page size on printing
Reply #1 - Jan 28th, 2009 at 2:57pm
Try this:
PrintDocumentImageableArea ia = null;
XpsDocumentWriter w = PrintQueue.CreateXpsDocumentWriter(ref ia);
if (w != null)
	DiagramPaginator dp = (DiagramPaginator)diag.DocumentPaginator;
	dp.PageSize = new Size(width, height);
	w.Write(dp);
vtortola
Reply #2 - Jan 28th, 2009 at 4:05pm
Work good for printing, but how could I do it for preview?
Cheers.
Reply #3 - Jan 28th, 2009 at 4:14pm
Using the same DiagramPaginator dp object,
MemoryStream ms = new MemoryStream();
Package pkg = Package.Open(ms, FileMode.Create, FileAccess.ReadWrite);
string pack = "pack://temp.xps";
var uri = new Uri(pack);
PackageStore.AddPackage(uri, pkg);
XpsDocument doc = new XpsDocument(pkg, CompressionOption.NotCompressed, pack);
XpsSerializationManager rsm = new XpsSerializationManager(new XpsPackagingPolicy(doc), false);
rsm.SaveAsXaml(dp);
var w = new Window();
DocumentViewer dv = new DocumentViewer();
dv.Document = doc.GetFixedDocumentSequence();
w.Content = dv;
w.Title = windowTitle;
w.ShowDialog();
PackageStore.RemovePackage(uri);
vtortola
Reply #4 - Jan 28th, 2009 at 4:22pm
Awesome ! Shocked
Thanks very much.
vtortola
Reply #5 - Jan 28th, 2009 at 4:47pm
hummm... a small question...
When I try to pass the size of the diagram, the shapes appears giant, and if for example I have a diagram where there is just one shape and the diagram fit it, appears splitted in several pages...  I think that is a issue related with the DPI, have you any thought about where could I set that?
Cheers.
vtortola
Reply #6 - Jan 29th, 2009 at 10:53am
Sorry but I don't get it, could you do a small example when you print the full diagram in a single page with the same size than the diagram?
Thanks.
Reply #7 - Jan 29th, 2009 at 12:01pm
The code above works fine in my test app. You are specifying the page size in WPF 96dpi points, right? With what Diagram.Bounds and page size values are you seeing problems?
vtortola
Reply #8 - Jan 29th, 2009 at 1:14pm
Possibly I'm misunderstanding something.
How do you translate the diagram bounds to page size?
Reply #9 - Jan 29th, 2009 at 1:51pm
You don't; DocumentPaginator does that. So what are your diagram.Bounds and page size values?
vtortola
Reply #10 - Jan 29th, 2009 at 3:28pm
I've built a small application, the I tried with several sizes and works fine, then I discover the problem that was make me obtain bad previews
I create a diagram, delete a couple of nodes,  ResizeToFitItems and preview, the diagram appears chopped.
I can provide a example if you need it: https://www.vtortola.net/files/DataBaseDiagramming.zip
Open the diagram, delete the two nodes at the top, click on the "fit" button in the toolbar, and then click "print" button.
Cheers.
Reply #11 - Jan 30th, 2009 at 9:28am
This version should fix that:
https://mindfusion.eu/_beta/wpfdiag211.zip
Cheers.
vtortola
Reply #12 - Jan 30th, 2009 at 10:23am
Perfect man Smiley
So, when this beta is going to be released? (I can't release a version of our software with the "WpfDiagram 2.1.1 beta" Tongue )
Cheers.
Reply #13 - Jan 30th, 2009 at 10:50am
When you stop reporting bugs Tongue We can send you a build without the label, but there are a few more unresolved problems, so you release on your own risk ...
vtortola
Reply #14 - Jan 30th, 2009 at 1:10pm
Ok, we'll wait for the safe release Tongue
