Normal Topic how to avoid links to overlap any node ? (Read 3859 times)
jay
Feb 4th, 2009 at 10:03am
   Whenever I move any node  in diagram, the links over lap some nodes or parent/ child node.
   How to resolve this problem.
Thank you.
Re: how to avoid links to overlap any node ?
Reply #1 - Feb 4th, 2009 at 10:44am
DiagramLink.setAutoRoute(true);
jay
Reply #2 - Feb 4th, 2009 at 12:53pm
hi  Stoyan,
    Thanks for reply. I have tried this solution but it is not working.
    I have added ((DiagramLink)e.getLink()).setAutoRoute(true);
on the link creation event.
the code block also having statements ;
((DiagramLink)e.getLink()).setAllowMoveEnd(true);
((DiagramLink)e.getLink()).setAllowMoveStart(true);
Thank you
Reply #3 - Feb 4th, 2009 at 1:15pm
If you have some large nodes in the background, call setObstacle(false) for them.
jay
Reply #4 - Feb 5th, 2009 at 5:22am
hi Stoyan,
            sorry, things were not working because of browser cache. later I cleared it and tested application your solution worked.
Thank you.
