Normal Topic Prevent drawing of new node (Read 1082 times)
JB
Feb 5th, 2009 at 10:17am
I'm evaluating FlowChart.Net and am using trial version 5.1.1.
I have a drag-and-drop implementation between 2 DiagramViews. How do I prevent users from drawing their own nodes on the drop view? I only want them to draw links and move nodes but not to draw new ones. Setting the DiagramView.Behaviour property doesn't have any affect.
Johan
Re: Prevent drawing of new node
Reply #1 - Feb 5th, 2009 at 10:26am
DiagramView.Behavior = DrawLinks should enable that. As with the inplace edit issue, check if the runtime DiagramView is the same one for which you set the properties in design-time, and make sure there isn't some call to DiagramView.LoadFromXml that loads different values.
