Hot Topic (More than 10 Replies) move a diagram (Read 4973 times)
tzippy
move a diagram
Feb 12th, 2009 at 2:31pm
My diagram is bigger than the window.
Is there an Option to move the diagram by the mouse?
I don't want using a scroll.
10X
Re: move a diagram
Reply #1 - Feb 12th, 2009 at 2:38pm
ALT + dragging should pan the diagram, but it still requires a ScrollViewer. If by 'I don't want using a scroll' you mean you don't want scrollbars visible, set the ScrollbarVisibility properties of the ScrollViewer to hide them.
tzippy
Re: move a diagram
Reply #2 - Feb 12th, 2009 at 2:54pm
Is it available to move the diagram with buttons?
Re: move a diagram
Reply #3 - Feb 12th, 2009 at 2:56pm
Yes, if you set the MiddleButtonAction or RightButtonAction property to Pan.
tzippy
Re: move a diagram
Reply #4 - Feb 12th, 2009 at 3:06pm
I mean buttons on the screen.
Re: move a diagram
Reply #5 - Feb 12th, 2009 at 3:09pm
Set the diagram's ScrollX and ScrollY properties - still requires a ScrollViewer parent.
tzippy
Re: move a diagram
Reply #6 - Feb 12th, 2009 at 3:13pm
Is there an option to set the 'LeftButtonAction' to pan, like RightButtonAction?
Re: move a diagram
Reply #7 - Feb 12th, 2009 at 3:15pm
There isn't one.
Naomi
Re: move a diagram
Reply #8 - Feb 12th, 2009 at 3:30pm
Can you explain my the logic? or the idea?
How can the user guess that he has to press on ALT in order to pan? Or right click?
Didn't you have a function, I can use for the moving?
Thank's.
Re: move a diagram
Reply #9 - Feb 12th, 2009 at 3:36pm
They can guess it the usual way - from your documentation or from a tooltip 8) Also using the middle mouse button (pressing down the mouse wheel if the mouse is without a middle button) for panning is pretty common, e.g. see MS Word or any browser. As mentioned above, you can change the scroll position programmatically by setting ScrollX and ScrollY. For the time being, you could handle the diagram's mouse events and change the scroll position from the MouseMove handler if you need panning with the left button.
tzippy
Re: move a diagram
Reply #10 - Feb 15th, 2009 at 12:40pm
Is there an option to add the property "pan" to the Behavior of the diagram your next version?
Re: move a diagram
Reply #11 - Feb 16th, 2009 at 8:43am
Yes, we can do that.
tzippy
Re: move a diagram
Reply #12 - Feb 16th, 2009 at 8:54am
Thanks a lot  Smiley
