Normal Topic Change Layout and keep positions (Read 3344 times)
tzippy
Feb 18th, 2009 at 9:15am
I want to arrange the layout diagram by treelayout,
but I want the nodes to keep their positions.
How can I do that?
thanks
Re: Change Layout and keep positions
Reply #1 - Feb 18th, 2009 at 9:26am
You can only keep the position of the root node. Set TreeLayout.KeepRootPosition = true before calling Arrange().
tzippy
Reply #2 - Feb 18th, 2009 at 9:43am
but what about the other nodes?
I need to keep their positions,
and arrange only the links.
Reply #3 - Feb 18th, 2009 at 10:06am
Try the TreeLayout.UpdateLink method if you need only to set the style of a link to match the rest of the tree links.
tzippy
Reply #4 - Feb 18th, 2009 at 11:15am
Is there an option to define the treelayout to ignore some links?
I want the links to be aranged, but with no effect on the nodes.
Reply #5 - Feb 18th, 2009 at 11:28am
Try calling UpdateLink in a loop. You could arrange only a part of the tree by calling Arrange(DiagramItemCollection), but the collection must contains both nodes and links.
