Normal Topic Display text under ShapeNode (Read 1827 times)
JB
Feb 18th, 2009 at 11:33am
I was looking at your Network Sample -> Ready Diagram demo and was wondering how you get the text, such as Printer, Home, User, etc.,to display under the node (image)?
Many thanks,
JB
Re: Display text under ShapeNode
Reply #1 - Feb 18th, 2009 at 11:41am
In that case the labels are separate nodes attached to the icon nodes through the DiagramNode.AttachTo() method. They are also Transparent and Locked.
Another possibility is to define a custom shape whose text region is below the outline, i.e. the text area Y coordinates are > 100.
JB
Reply #2 - Feb 19th, 2009 at 12:57pm
Hi Stoyan,
Thanks again for all your help, I truly appreciate it tremendously!!
My last question: How do I get the attached child node? E.g. If I make changes to my parent node the changes must also be reflected in the child node. I used childNode.AttachedTo(parentNode, AttachToNode.BottomLeft) to do the attaching.
Johan
Reply #3 - Feb 19th, 2009 at 1:07pm
Hi Johan,
Try with
if (someNode.SubordinateGroup != null)
     childNode = someNode.SubordinateGroup.AttachedNodes[0];
