Normal Topic Programatically Create Links b/w ShapeNodes (Read 1650 times)
SandeepGowda
Feb 16th, 2009 at 6:13am
UseCase: Lets assume that we have 3 shapeNode linked sequentially, if i delete middle shapeNode,can we link programatically first Node to Last Node.
thanks in advance
regards
Sandeep
Re: Programatically Create Links b/w ShapeNodes
Reply #1 - Feb 16th, 2009 at 8:40am
private void RemoveFromSequence(ShapeNode node)
	DiagramNode pred = node.IncomingLinks.Count > 0 ?
		node.IncomingLinks[0].Origin : null;
	DiagramNode succ = node.OutgoingLinks.Count > 0 ?
		node.OutgoingLinks[0].Destination : null;
	diagram.Nodes.Remove(node);
	if (pred != null && succ != null)
		diagram.Factory.CreateDiagramLink(pred, succ);
SandeepGowda
Reply #2 - Feb 20th, 2009 at 3:26pm
        3
    4         5
    lets assume.
     Task 1 has outgoing to Task 3
     Task 2 has outgoing to Task 3
     Task 3 has outgoing to Task 4
     Task 3 has outgoing to Task 5
if task 3 is deleted,
     1         2
    4         5
     Task 1 has outgoing to Task 4
     Task 2 has outgoing to Task 5
     Task 1 has outgoing to Task 5
How easily programatically links can be created from above usecase.
regards
sandeep
Reply #3 - Feb 20th, 2009 at 3:41pm
Should look like this:
foreach (DiagramLink incl in node.IncomingLinks)
	foreach (DiagramLink outl in node.OutgoingLinks)
		diagram.Factory.CreateDiagramLink(incl.Origin, outl.Destination);
