Hot Topic (More than 10 Replies) control the order of the nodes (Read 8206 times)
tzippy
Feb 19th, 2009 at 2:14pm
How can I control the order of the nodes?
For example, I want to add a node between other two nodes, or in the right side of other node, etc.
10X
Re: control the order of the nodes
Reply #1 - Feb 19th, 2009 at 2:18pm
If you mean the order of child nodes in TreeLayout, this depends on the order of links from parent to child nodes in the parent' OutgoingLinks collection. So you could rearrange OutgoingLinks before applying TreeLayout and will get the child nodes in the same order as the links in that collection.
tzippy
Reply #2 - Feb 19th, 2009 at 2:34pm
Thanks.
Can you explain me please the order?
I mean, when I'm adding a child, is it on the left side of the diagram, right side or in the middle?
Reply #3 - Feb 19th, 2009 at 2:40pm
The last link that you create to connect a parent node to a child goes last in the parent's OutgoingLinks collection, and applying TreeLayout moves that last child to the right of the other children of that node. If you remove the link from OutgoingLinks and insert it again at a different position, applying the layout would result in moving the respective child node to the same position in the row of children.
tzippy
Reply #4 - Feb 19th, 2009 at 2:50pm
And what about the other nodes?
I mean the brothers.
Reply #5 - Feb 19th, 2009 at 2:53pm
The links coming out from a parent are placed in the same order they are in OutgoingLinks, and as consequence, their Destination nodes (the children) are in that order too. To change the order of sibling nodes, find their parent and set the positions of the siblings' incoming links inside the parent's OutgoingLinks list.
tzippy
Reply #6 - Feb 24th, 2009 at 1:28pm
I would like to know the order of the links.
In the diagram there is node with 8 OutGoingLinks.
Their indexes are: 2,3,0,1,6,7,4,5.
How can I order them like this: 0,1,2,3,4,5,6,7 simply?
Reply #7 - Feb 24th, 2009 at 1:35pm
node.OutgoingLinks.Clear(), and then call node.OutgoingLinks.Add() for each link in the order you need them. That probably would require you to keep a copy of the outgoing links collection so you don't lose the link references.
tzippy
Reply #8 - Feb 24th, 2009 at 2:05pm
Thanks a lot.
Is there an option to order the nodes automatic from right to left or left to right, Or I need to write it myself?
Reply #9 - Feb 24th, 2009 at 2:37pm
There is the TreeLayout.Direction property, but left-to-right and right-to-left there define the order from parent to child node, and not the relative order of child nodes. So you might have to reverse the order of OutgoingLinks if what you need is reversing the order of children.
tzippy
Reply #10 - Mar 23rd, 2009 at 3:18pm
I arranged the outgoingLinks,
But they aren't shown according to that order.
Reply #11 - Mar 23rd, 2009 at 6:38pm
Seems we broke this while implementing your 'assistant' nodes. We'll upload a fix tomorrow.
Reply #12 - Mar 24th, 2009 at 9:49am
Should work as expected with this version:
https://mindfusion.eu/_beta/wpfdiag_treeltfix.zip
tzippy
Reply #13 - Mar 29th, 2009 at 1:08pm
I checked the new dlls you sent me, but my problem was not fixed. I want explain again what is my problem: I have a DiagramNode that its OutGoingLinks property contains 4 links. I want that the links will be ordered in the same order they are in the OutGoingLinks list, but they aren't: The OutGoingLinks list contains the following nodes in this order: Node A, Node B, Node C and Node D, but in the diagram, after I added the links and did TreeLayout.Arrange operation the nodes are displayed in the following order from left to right: Node C, Node D, Node A, Node B. Why it is so? Why the nodes are not displayed in the same order their links are ordered in the OutGoingLinks  list???
Reply #14 - Mar 30th, 2009 at 6:52am
Are you sure your project correctly references the new dll? Please check if after rebuild the dll in the bin/debug folder is the same as the one from the zip file.
