Normal Topic Issue related to LayeredLayout. (Read 1327 times)
Shane
Mar 29th, 2009 at 10:46am
I have used the LayeredLayout to arrange the items on the diagram.
The issue is after arrangement the items leave the diagram area which is not desired.
I have tried using the
diagram.RestrictItemsToBounds = RestrictToBounds.InsideOnly;
but its not working.
I have also tried the
diagram.ResizeToFitItems(20);
this makes the diagram to loose the client area which is again not desired.
I cant use diagram.ZoomToFit() method .
Any suggestion how can I make it work.
Shane.
Re: Issue related to LayeredLayout.
Reply #1 - Mar 30th, 2009 at 6:49am
What area is occupied by LayeredLayout depends on the size of nodes and the layout's LayerDistance property. What's wrong with calling diagram.ResizeToFitItems()?
