Hot Topic (More than 10 Replies) Labels of nodes (Read 11467 times)
jaiswalamit
Labels of nodes
Feb 23rd, 2009 at 3:03pm
Is there a way where I can put some labels to the shape nodes. The current property uses the text which I provide on the body of the image. I want the label to appear outside of the image (may be bottom). Please help. Thanks,
Amit
Re: Labels of nodes
Reply #1 - Feb 23rd, 2009 at 3:29pm
Hi Amit,
At this time you can do that only by creating a user control and using ControlNodes to display its instances in the diagram.
jaiswalamit
Re: Labels of nodes
Reply #2 - Feb 27th, 2009 at 7:01am
Hi Stoyan,
Is there any plan of having this feature inbuilt in the default ShapeNodes in near release of DG.
Amit
Re: Labels of nodes
Reply #3 - Feb 27th, 2009 at 7:39am
Hi Amit,
There will be ImageAlign and TextFormat properties available in the 1.0.2 release; you could use them to align the image to the top of the node and the text to the bottom. This will let you create icon-like nodes when combined with the Transparent property.
We also plan to add support for ControlTemplates to this release - they will let you place the text below the geometric shape if you need to display the shape as well.
jaiswalamit
Re: Labels of nodes
Reply #4 - Feb 27th, 2009 at 9:40am
Thanks very much Stoyan
Re: Labels of nodes
Reply #5 - Mar 5th, 2009 at 11:55am
Hi Amit,
This version adds the ImageAlign and TextFormat properties:
https://mindfusion.eu/_beta/diaglite_align.zip
jaiswalamit
Re: Labels of nodes
Reply #6 - Mar 5th, 2009 at 12:39pm
Kudos to you and your team.  Cheesy
Amit
jaiswalamit
Re: Labels of nodes
Reply #7 - Mar 17th, 2009 at 7:57am
Hi Stoyan,
The text is still coming on top of the image. I used both the properties for Image and Text like:
//create a new ShapeNode
//Assing to BitmapImage
mynode.ImageAlign = ImageAlign.TopCenter;
myNode.Text = "Node Text"; //node label
myNode.FontSize = 7; //reducing the sise to fit in
myNode.TextFormat.Alignment = StringAlignement.Far; //I tired with near, center no use;
The Image is shifted to top far, but the text is still coming on top of it, please help.
Amit
Re: Labels of nodes
Reply #8 - Mar 17th, 2009 at 9:22am
Hi Amit,
Create a new TextFormat instance, set its alignment members and assign it to myNode.TextFormat.
jaiswalamit
Re: Labels of nodes
Reply #9 - Mar 17th, 2009 at 9:55am
Hi Stoyan,
I think you meant create a new Instance of StringFormat correct?
I did this as well but the same problem:
StringFormat sfmt = new StringFormat();
sfmt.Alignment = StringAlignment.Far; //Near Center tried all 3
sfmt.LineAlignment = StringAlignment.Far; //Near Center tried all 3
myNode = sfmt;
//the text still appears on top of the images aligned to TopCenter
Amit
Re: Labels of nodes
Reply #10 - Mar 17th, 2009 at 11:01am
Hi Amit,
This worked for me
private void OnChangeStringFormat(object sender, RoutedEventArgs e)
	if (diagram.ActiveItem != null)
		if (diagram.ActiveItem is ShapeNode)
			(diagram.ActiveItem as ShapeNode).TextFormat = sfmt;
Are you sure you are using the latest version? What kind of Shape have you assigned to the node?
jaiswalamit
Re: Labels of nodes
Reply #11 - Mar 17th, 2009 at 11:40am
Hi Stoyan,
1. I am using the Assembly Version: 1.0.1.24923 (534KB)
1. I am using Rectange as the ShapeNode for my node
I have image also assigned to that node.
I too have a code similar like yours, but the image n text are overlapping.
Amit
jaiswalamit
Re: Labels of nodes
Reply #12 - Mar 17th, 2009 at 11:44am
Hey got this working now. I had created a StringFormat object only once for all nodes in my application load, and then was resuing for each nodes I created later. But that was not working.
Then I created a new object of StringFormat for each new node I create, and then it is working properly as expected (labels below images).
Any idea why is this behavior.
Amit
Re: Labels of nodes
Reply #13 - Mar 17th, 2009 at 12:06pm
Perhaps because the TextFormat setter checks if (textFormat != value) ...  8)
jaiswalamit
Re: Labels of nodes
Reply #14 - Mar 17th, 2009 at 12:48pm
Hi Stoyan,
My SF object was well initialized before I assigned it to any node's TextFormat property, hence even if the check you mentioned shouldn't cause this to fail. But it's fine, I don't mind creating new instances each time, just hope it's good on memory.
Btw, one issue which I am observing is that if my labels are big (areound 2 or 3 words) then they break into multiline - which is fine but sometimes they get overlapped by the image of the node. Is there anyway how I can make sure that the lablels always start below the image area (may be after a gap of a few pixels).
Is there any email id where I can send you the screen shot explaining the behavior.
Amit
