Normal Topic Display of overlapping appointments (Read 1965 times)
Darko
Mar 2nd, 2009 at 8:05pm
when the EnableCollision property is enabled and two or more appointments collide/overlap, the entire day is split into columns and even the appointments that don't overlap with any other are displayed shrunken.
In the image below, I'd expect the topmost, bottom-most and the middle appointments to appear in full width.
Is there any way to do this? Perhaps a simple property I'm missing?
Currently:
Desired:
Darko
Re: Display of overlapping appointments
Reply #1 - Mar 4th, 2009 at 7:17am
Turning paddings off (through TimetableSettings.EnablePadding property) results in the items no longer spanning all of the unoccupied space. At this point there is no way to fix this unless you enable paddings again.
Reply #2 - Mar 5th, 2009 at 9:46am
Quick update: This issue has been fixed and will be available in the next release of the component.
