Normal Topic DynamicLinks problem (Read 1512 times)
Thomas Nygaard
Mar 11th, 2009 at 10:02am
Hi
I have a problem with the DynamicLinks property.
When I move the nodes manually in the diagram it works just fine, but when I move the nodes via the Move method the links aren't arranged correct.
Here is a simple code example.
private void Form1_Load(object sender, EventArgs e)
diagram1.DynamicLinks = true;
ShapeNode node1 = diagram1.Factory.CreateShapeNode(10, 10, 10, 10);
ShapeNode node2 = diagram1.Factory.CreateShapeNode(50, 10, 10, 10);
DiagramLink link = diagram1.Factory.CreateDiagramLink(node1, node2);
node1.Move(100, 10);
The arrow stays on the left side of node2 instead of being moved to the right side of the node.
Am I missing something?
Yannik
Re: DynamicLinks problem
Reply #1 - Mar 11th, 2009 at 10:56am
Call link.UpdateIntersections() after moving the node.
Thomas Nygaard
Reply #2 - Mar 11th, 2009 at 11:52am
Yes, it works Smiley
Yannik
