Normal Topic PathFinder With ContainerNode Not Working (Read 1835 times)
Aziz ur Rahman
Mar 11th, 2009 at 10:14am
PathFinder.FindAllPaths or FindShortestPath or FindLongestPath
Source Outside Container
Destination Inside Container
PathFinder will work and say no Path even there is a path
Source Inside Container
PathFinder will NOT work and through exception
Destination Outside Container
Exception says "Values can not be null"
One more thing..
If source and destination both are outside of Container but there are some connecting nodes inside a container, then it will work fine.
Please suggest any solution
http://weblogs.com.pk/photos/aziz/images/149880/original.aspx
Syed Aziz ur Rahman
Re: PathFinder With ContainerNode Not Working
Reply #1 - Mar 11th, 2009 at 2:53pm
Aziz ur Rahman
Reply #2 - Mar 12th, 2009 at 1:38pm
I have tested the application using the version 5.2.
Is this an upgrade after 5.2?
It this a demo version?
We have purchased full verion before. Will demo sign come in the appliction?
Syed Aziz ur Rahman
Reply #3 - Mar 12th, 2009 at 2:03pm
Email me your company name or order id and I will send you the licensed version.
