Hot Topic (More than 10 Replies) Assistants in one side (Read 9922 times)
tzippy
Mar 12th, 2009 at 2:46pm
I'm using assistants.
Is there option to add assistants only in one side? (I mean only in the right side of the link or only in the left side of the link).
Re: Assistants in one side
Reply #1 - Mar 12th, 2009 at 4:15pm
There isn't such option.
Naomi
Reply #2 - Mar 18th, 2009 at 3:14pm
I'm using your diagram, and I like the new feature of the assistants.
But how can I define the side?
I want to define the side for each node, some of them in the right side, and some of them in the left.
Can you add this property? I think it is very very simple.
I will really appreciate it.
Thank in advanced.
Reply #3 - Mar 18th, 2009 at 3:57pm
It might be simple but our developers have tons to do. You can wait for us to do it when convenient for our schedule, or otherwise we can do it for a small fee as a compensation for delaying our releases:
http://www.mindfusion.eu/services.html
tzippy
Reply #4 - Apr 2nd, 2009 at 11:19am
I'm using the new dll's.
But there is a problem with these dll's.
The event SelectionChanged happens when I click on a selected link.
(I have one link, I select it, when I click on it again this event happens again).
tzippy
Reply #5 - Apr 2nd, 2009 at 11:44am
I have one more problem with these dll's that wasn't before.
The diagram is initilized with one transparent grid node.
Reply #6 - Apr 2nd, 2009 at 2:32pm
This should fix the selection event raising when not needed:
https://mindfusion.eu/_beta/wpfdiag_selchanged.zip
The "grid node" might the lanes or alignment grid, if you have enabled EnableLanes or ShowGrid properties inadvertently.
tzippy
problem with selection
Reply #7 - Apr 19th, 2009 at 11:26am
I'm using this version and I have a problem that wasn't before:
On each node there are button and popoup.
On the pre version - click on them raised the events of click that I wrote.
On this version - Click on them raise the event selectionChange.
tzippy
Re: problem with selection
Reply #8 - Apr 19th, 2009 at 11:55am
tzippy wrote on Apr 19th, 2009 at 11:26am:
Reply #9 - Apr 20th, 2009 at 6:50am
It raises both NodeClicked and SelectionChanged in my test project:
https://mindfusion.eu/_samples/LogEvents.zip
The zip also contains the latest version of the control, in case our developers have changed something in the last few days.
tzippy
Reply #10 - Apr 20th, 2009 at 8:00am
Still I have problems with the new dll's.
There is a button on the node.
The node is selected.
Click on the button doesn't work.
With the old dll's the Click works well.
Reply #11 - Apr 20th, 2009 at 10:49am
Is it a Button control added to the diagram through DiagramNodeAdapter, or it's a ShapeNode for which you handle NodeClicked?
tzippy
Reply #12 - Apr 20th, 2009 at 10:55am
It's a Button control added to the diagram through DiagramNodeAdapter.
Reply #13 - Apr 21st, 2009 at 11:44am
Try that with this version:
https://mindfusion.eu/_beta/wpfdiag_buttonclick.zip
tzippy
Reply #14 - Apr 21st, 2009 at 1:13pm
It Works.
