Hot Topic (More than 10 Replies) Assistants in one side (Read 9935 times)
tzippy
Re: Assistants in one side
Reply #15 - Apr 26th, 2009 at 10:11am
There is a little problem,
I add assistant in right and after it in left,
the assistant on the left side is too low.
If I add the left assistant first and than the right assistant, it works well.
Reply #16 - Apr 27th, 2009 at 7:52am
TreeLayout creates a new row after each right-assistant node. Child nodes are processed in the order they are found in the parent's OutgoingLinks collection, so you might have to sort OutgoingLinks, as I believe you already do in some other cases.
tzippy
Reply #17 - May 11th, 2009 at 7:32am
Hi
When I asked the feature of setting the assistants' side, I asked the assistants won't be added as a pair, so the assistant in the one side won't be affected by the assistant in the other side. For example, we can define one big assistant in the right, and 3 small assistants in the left.
But I checked it, and I saw the assistants were added as a pair, so the size of the one assistant causes the space in the other side.
How can I fix it?
Reply #18 - May 11th, 2009 at 8:36am
Set TreeLayout.CompactAssistants = true.
tzippy
Reply #19 - May 11th, 2009 at 9:01am
It doesn't work Sad
Reply #20 - May 12th, 2009 at 10:26am
Yes, it does, though perhaps not exactly as you expect it. Even if the nodes are assistants, they are still assigned to tree levels, and the level height is determined by the largest node. You cannot have nodes placed independently from levels. What CompactAssistans does is to decouple the node pairs, so if you have less assistants on one side than on the other, they will occupy the topmost levels, rather than be placed on non-adjacent levels.
