Normal Topic Diagram.RegisterItemClass (Read 3266 times)
Aziz ur Rahman
Mar 15th, 2009 at 3:05pm
1) How to check that a particular class is already registered or not?
2) How to un register it? (I donot want the class to get serialzed using saveto methods)
Syed Aziz ur Rahman
Re: Diagram.RegisterItemClass
Reply #1 - Mar 16th, 2009 at 8:50am
1) You might do something like this:
if ((diagram as IItemFactory).TypeTable[typeof(IconNode)] == null)
     Diagram.RegisterItemClass(typeof(IconNode), "IconNode", 0);
2) If you don't want it serialized, you could simply not call the Register method. You can access ClsidTable and TypeTable as shown above - they are Hashtable objects - and remove the type from the first table and the id from the second table.
Aziz ur Rahman
Reply #2 - Mar 16th, 2009 at 9:02am
My application is a tab based application means that i can have several instance of diagrams at the same time in different tabs.
So do i have to do this with each and every instance of diagram?
Is not there a share method for unRegistering and checking for registering as it is there for register.
Syed Aziz ur Rahman
Reply #3 - Mar 16th, 2009 at 9:03am
This is something you can do only once for the application lifetime, you do not have to register the custom types with each Diagram instance.
Aziz ur Rahman
Reply #4 - Mar 16th, 2009 at 9:05am
First .. thanks for your quick replies.
I was just checking the Diagram.Register method using Reflector and came to know that you have shared/static Hashtable in diagram class. Why not provide a removal method from the same static hashTables?
Syed Aziz ur Rahman
Aziz ur Rahman
Reply #5 - Mar 16th, 2009 at 9:07am
I know that Register is done once in the life time of an application. i was asking about UN register( removal from hash table). Do i have to do this with all instances of Diagram class?
Syed Aziz ur Rahman
Reply #6 - Mar 16th, 2009 at 9:23am
These hashtables are static/shared too.
