Normal Topic Query related to zooming. (Read 1005 times)
anurodhora
Mar 18th, 2009 at 12:02pm
I have a requirement of zoom-in and zoom-out functionality on mouse wheel event in my application which is running smooth. But I am facing an issue which is I need my diagram to occupy complete client area no matter whether I zoom-in or zoom-out i.e the diagram should always fit the size of the window only the elements in the diagram should get zoomed in or zoomed out.
Any suggestion how can I accomplish the above task.
Following is the code I am using for the zooming action :
private void OnDiagramMouseWheel(object sender, MouseWheelEventArgs e)
e.Handled = true;
Point p = e.GetPosition(Parent as ScrollViewer);
Point oldcurpos = diagram.ClientToDoc(p);
diagram.ZoomFactor += e.Delta / 60;
Point newcurpos = diagram.ClientToDoc(e.GetPosition(Parent as ScrollViewer));
double diffx = (oldcurpos.X - newcurpos.X);
double diffy = (oldcurpos.Y - newcurpos.Y);
diagram.ScrollTo(new Point(
diagram.ScrollX + diffx < 0 ? 0 : diagram.ScrollX + diffx,
diagram.ScrollY + diffy < 0 ? 0 : diagram.ScrollY + diffy));
Thanks in advance.
Anurodh.
