Normal Topic How to change the cursor behavior in pan mode (Read 1624 times)
Kiran_G
May 17th, 2011 at 11:15am
Using "MindFusion.Diagramming.Wpf.Diagram"  i am generating the diagram.
As of now when set the behaviour of diagram to  "Pan" and click on the diagram then cursor is set to hand to move it.
But my requirement is when behavior is set to "Pan" the cursor should be hand even on mouse over on that diagram.Please suggest the approach to implement this.
Re: How to change the cursor behavior in pan mode
Reply #1 - May 17th, 2011 at 11:22am
Try setting Diagram.OverrideCursor to Hand if the control should always show a hand cursor.
