Normal Topic Node handles change color whe load diagram (Read 4992 times)
PDM.
Senior Member
May 18th, 2011 at 7:22am
The custom node handles change color to RED, when load diagram already saved.
Why this happen?
How correct this problem?
Best regards.
Re: Node handles change color whe load diagram
Reply #1 - May 18th, 2011 at 7:54am
Do the handles get disabled, or just their color changes?
PDM.
Senior Member
Reply #2 - May 18th, 2011 at 1:16pm
Just color change to RED.
Reply #3 - May 18th, 2011 at 1:32pm
By custom node handles do you mean custom-drawn ones? If so, what does your DrawAdjustmentHandles event handler look like?
PDM.
Senior Member
Reply #4 - May 19th, 2011 at 6:27am
var TopLeft = new Point(0, 0);
          e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(TopLeft, size));
Is how i construct my custom handles.
This is what you ask?
Reply #5 - May 19th, 2011 at 10:48am
Our bad, the control cannot serialize DrawingBrush objects at this time, so the PatternBrush value is lost. For the time being you can either pass your own DrawingBrush instance to DrawRectangle, or reset SelectedItemHandlesStyle.PatternBrush to its original value after loading.
PDM.
Senior Member
Reply #6 - May 19th, 2011 at 2:14pm
Amazing !! finally i report one bug ! : )
Please can showme how rester after load?
When this be fixed¿
Best regards!
Reply #7 - May 19th, 2011 at 2:52pm
Try this:
var defaultStyle = new HandlesVisualStyle(form);
form.SelectedItemHandlesStyle.PatternBrush = defaultStyle.PatternBrush;
PDM.
Senior Member
Reply #8 - May 20th, 2011 at 11:43am
Thankyou, this work !
