Normal Topic PathFinder setting limit for Cycle Length (Read 4065 times)
yeng
Aug 19th, 2010 at 2:42am
i'm working for developing a analysis software using trial version of wpfdiagram. is it possible that setting limit for cycle length when finding all cycles? or retrieve partial list of cycles while finding is in progress? coz we may hav a huge list of cycles in our diagram. thnx.
Re: PathFinder setting limit for Cycle Length
Reply #1 - Aug 19th, 2010 at 6:32am
We have added an EnumAllCycles iterator method here:
https://mindfusion.eu/_beta/wpfdiag_cycleiterator.zip
It uses the "yield" instruction to return each cycle during the iteration, and you can process it immediately without waiting for all cycles to be found. E.g. you could update the UI while the foreach loop runs, or break it when you find a certain number of cycles.
yeng
Reply #2 - Aug 20th, 2010 at 5:30am
got it. thnx alot  Smiley
yeng
Reply #3 - May 23rd, 2011 at 7:13am
hi stoyo, we lost the library and found that the link is broken. could you update the link again?
Reply #4 - May 23rd, 2011 at 7:24am
This is now available in official releases since version 2.5.
yeng
Reply #5 - May 23rd, 2011 at 7:53am
thnx for the prompt reply.  Smiley
