Hot Topic (More than 10 Replies) Query regarding Zooming. (Read 7737 times)
Anant_Shukla
Mar 20th, 2009 at 11:58am
I have a requirement of Zoom-In and Zoom-Out functionality in my application on MouseScroll event. For the pupose I have used the following code :
private void OnDiagramMouseWheel(object sender, MouseWheelEventArgs e)
e.Handled = true;
Point p = e.GetPosition(Parent as ScrollViewer);
Point oldcurpos = diagram.ClientToDoc(p);
diagram.ZoomFactor += e.Delta / 60;
Point newcurpos = diagram.ClientToDoc(e.GetPosition(Parent as ScrollViewer));// diagram.ClientToDoc(e.GetPosition(diagram));
double diffx = (oldcurpos.X - newcurpos.X);
double diffy = (oldcurpos.Y - newcurpos.Y);
diagram.ScrollTo(new Point(
diagram.ScrollX + diffx < 0 ? 0 : diagram.ScrollX + diffx,
diagram.ScrollY + diffy < 0 ? 0 : diagram.ScrollY + diffy));
The issues faced by me are as follows :
1. In my diagram I have a node placed at coordinates (200,-80). Now when I Zoom-In the diagram this node disappears even with the slightest of zoom.
2. I require the diagram should always fit to the container i.e when I Zoom-In and Zoom-Out the diagram should not get resized only the items within that diagram should get zoomed in and zoomed-out. The diagram should always fit to the container.
3. The zoom-in and zoom-out should be respective to the mouse position while moving the mouse wheel.
Any suggestion how can I accomplish these requirements.
Thanks and Regards,
Anant Shukla.
Re: Query regarding Zooming.
Reply #1 - Mar 21st, 2009 at 8:09am
1. Replace the ScrollTo call with
     diagram.ScrollX + diffx < diagram.Bounds.X ? diagram.Bounds.X : diagram.ScrollX + diffx,
     diagram.ScrollY + diffy < diagram.Bounds.Y ? diagram.Bounds.Y : diagram.ScrollY + diffy));
Reply #2 - Mar 21st, 2009 at 8:14am
2. Set the ScrollViewer's Background to have the same value as the diagram's BackBrush and the effect should be pretty much the same.
Reply #3 - Mar 21st, 2009 at 9:09am
3. The code above should do that when the diagram.Bounds is larger than the ScrollViewer's visible area. However if it's smaller, it won't work because it would require setting a new scroll position, and the ScrollViewer doesn't allow that when its content is smaller than the visible area. A solution is to always set diagram.Bounds to a value that would make the zoomed content larger than the scrollviewer, e.g. this seems to work
	e.Handled = true;
	double newScrollX = diagram.ScrollX;
	double newScrollY = diagram.ScrollY;
	Rect newBounds = diagram.ClientToDoc(
		new Rect(0, 0, scrollViewer.ActualWidth, scrollViewer.ActualHeight));
	newScrollX += diffx;
	newScrollY += diffy;
	newBounds.X = newScrollX;
	newBounds.Y = newScrollY;
	newBounds.Union(diagram.GetContentBounds(false, false));
	newBounds.Inflate(200, 200);
	diagram.Bounds = newBounds;
	diagram.ScrollTo(new Point(newScrollX, newScrollY));
Anant_Shukla
Reply #4 - Mar 21st, 2009 at 9:51am
Hi Stoyan,
Thanks for the sample code.
The code is working fine.
Whereas I do have another requirement which is I require the diagram to resize itself accordingly to fit all the items present on the diagram at moment of initialization of the diagram. The code used by me to initialize the diagram is as follows :
private void InitDiagram(Diagram diagram)
diagram.AllowSelfLoops = false;
diagram.AllowUnconnectedLinks = false;
diagram.AllowLinksRepeat = false;
diagram.Behavior = Behavior.Modify;
diagram.BackBrush = Brushes.LightBlue;
diagram.AutoResize = AutoResize.AllDirections;
new Rect(0,0,scrollViewer.ActualWidth, scrollViewer.ActualHeight));
newBounds.Inflate(50, 50);
Can you please tell me what I am missing here.
Thanks and Regards,
Anant Shukla.
Reply #5 - Mar 22nd, 2009 at 6:33am
Try the ZoomToFit method.
Anant_Shukla
Reply #6 - Mar 23rd, 2009 at 6:28am
Hi Stoyan,
There are few issues in the same Zoom-In and Zoom-Out functionality.
1. I needed the diagram should occupy the complete container area no matter I Zoom-In or Zoom-Out. You suggested to match the ScrollViewers background property with the diagram's backbrush property. But this do not resolve the issue because the diagram area still resizes when I Zoom-In or Zoom-Out. I do not want the diagram to resize it should always fit to the container.
2. I want my diagram should zoom to fit all the items present on the diagram when the diagram is initialized. I tried the ZoomToFit method but its not working and I also need the diagram to zoom only when required i.e if there is only one node in the diagram then it should get zoomed. The code used by me is as follows :
diagram.AutoScroll = false;
diagram.LinkCrossings = LinkCrossings.Arcs;
diagram.ZoomToFit();
3. In Your suggestion which is as follows :
" The code above should do that when the diagram.Bounds is larger than the ScrollViewer's visible area. However if it's smaller, it won't work because it would require setting a new scroll position, and the ScrollViewer doesn't allow that when its content is smaller than the visible area. A solution is to always set diagram.Bounds to a value that would make the zoomed content larger than the scrollviewer, e.g. this seems to work
Code:
e.Handled = true;
What is the "scrollViewer" variable can you describe in detail. How to declare that. Also after a particular value of zooming out it stops working.
Any suggestion how can I resolve above issues.
Thanks and Regards,
Anant Shukla.
« Last Edit: Mar 23rd, 2009 at 8:16am by Anant_Shukla »
Anshul
Senior Member
Reply #7 - Apr 9th, 2009 at 8:37am
Hi Stoyan,
I have tried this code for Zoom-In and Zoom-Out.
e.Handled = true;
Its working fine but only problem is that when I ScrollUp mouse for Zoom-Out,it Zoom -Out the node but also shifts the diagram to some upper position.
I want,Zoom-Out should be performed at the point of cursor only and it does not shifts the diagram when Zoom-In or Zoom-Out.
Thanks in advance,
Anshul
Reply #8 - Apr 9th, 2009 at 9:12am
This happens if the diagram is initially smaller than the scrollviewer, right?
Anshul
Senior Member
Reply #9 - Apr 9th, 2009 at 10:47am
how can i make size of diagram equals to size of scrollviewer ?
I have tried for the same in InitDiagram function by making equal height and width for both, but problem is still the same.when I ScrollUp mouse for Zoom-Out,it Zoom -Out the node but also shifts the diagram to some upper position.
1. Is their any other way to make diagram larger than or equal to scrollviewer ?
2. if the diagram is smaller,is it possible to Zoom-out on the node without shifting the diagram ?
Anshul
Reply #10 - Apr 9th, 2009 at 12:24pm
1. You could add this to the Window_Loaded handler:
diagram.Bounds = diagram.ClientToDoc(
2. Should be possible if you subtract the offset of the diagram's top-left corner from the scrollviers's top-left corner from ths point in the MouseWheel code:
p.X -= ???;
p.Y -= ???;
I don't know how you can find that offset though.
Anshul
Senior Member
Reply #11 - Apr 18th, 2009 at 7:22am
Hi Stoyan,
Zoom-In/Zoom-Out of  the nodes has done according to the center of the diagram,but I want to perform same operation at the cursor position.
how I can do this ?
Reply #12 - Apr 18th, 2009 at 7:31am
Anshul
Senior Member
Reply #13 - Apr 18th, 2009 at 8:28am
I have already tried this,its not working.
